Forced Induction Turbo kit for 99-02 corolla
Discussion in 'Powertrain' started by statik, Sep 27, 2005.
    statik New Member
    eh... no - i can tell you right now that kit would blow your motor up.
    DeebsTundra Big Tires :)
    Near VoRtEx
    Garrett T25 BB Turbo---224 Horse Power---280 Horse Power
    ...That's a 50% gain...isn't that more like 140%?
    Is that even possible?
    Phozenstone New Member
    maybe they were using XRS numbers i dunno
    Denver Rolla 98 impreza
    how can they be useing XRS nimbers... its a 99-02 kit... it would blow up even a built car...
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    Dr Tweak Mad Scientist
    Savannah, GA
    Which is too bad because that company has some decent rebuild kits, at least it seems.
    01rollas New Member
    there is no way in hell i would be able to handle that. even with the last engine i had which was built with high quality components except for the rings and stock timing chain.
    asn13oy Stepping Stones
    OC, CA
    There's an aftermarket timing chain?
    Savannah, GA
    I think the point that he was making was that there is not one otherwise he would have used it.
    -Doc
    Littleton, CO.
    eh we would have ANYTHING we want but since there's no enough demand we're still under lol
    OC, CA
    Yeah I finally realized that after I posted but decided not to delete it...I'm an old skool post whore.
    01rollas New Member
    thank you for clearing that up.and excatly if there was one i would have bought it and would of not had any problems right now or before.
    OC, CA
    Could you describe any problems you were having w/ the chain?
    Barnacules 100101101011011
    Duvall, WA
    Sorry for opening an old thread but I want to know what makes these kits so bad? I mean it sounds like they have the same components I would buy if I was going ot make a kit from scratch but they are bolt and drive kits. I want to turbo my car but over and over I can't reiterate how much I cannot have my car offline for more then a weekend and I dont think I can construct and install a kit in a weekend. Someone please tell me exactly why these kits are crap and back them up with evidence that is more then one single persons experience. Because if we always went by one persons experience then nobody would have got the SF kits either. I'm trying not to turn this into a rant but I'm only not purchasing this kit because everyone says its crap. can someone tell me why it isn't crap? What would you do different with a custom kit? I'm curious.
    You are correct, all turbo "kits" is composed of essentially the same items; turbo, manifold, charge pipes, down pipe, wastegate, intercooler, bypass valve, and fuel management. But the kit would not work if the plumbing, ie charge pipes and down pipe is not routed correctly with respect to your chassis/engine bay. It would be like buying a celica or MR2 turbo kit and trying to install it on ur rolla because yet again they are compose of the same parts. This kit is made by TSI and Hookedup96rolla have had some bad experiences with the fitment of their kits. TSI is definately not a reputable company
    http://vvti.net/forums/showthread.php?t=2338&page=2&pp=25
    Besides that their fuel management look like crap, Black box? c'mon that sounds as reliable as running a FMU. Fuel management is the most important piece of the puzzel and should be done right and tuned correctly to ensure the longivity of your engine.
    turbokits.com New Member
    Hey Cuztomrollaz98,
    What happnened with your car / kit that would make you call these crap? We have successfully sold many of these for the 1ZZ Corolla.
    Jesse @ Turbo Kits.com
    pupo New Member
    Well the only way of knowing if that kit is crap is looking at it maybe if they had actuals pictures of the kit installed on a car, with dyno chart. Other that that there is no way of knowing.
    On the other hand, you could make a custom setup maybe with little down time, all you have to do is plan it. First thing I did was install the plug for the oil drain, took the oil pan out wellded a fitting to it and put a cap in the hole and put the oil pan back to the car, it took me a few hours to do that. Next I did the return line and so on. Think about it.
    I have replied to some good questions here:
    http://TRDforums.com/forum/showthread.php?p=59286&posted=1#post59286
    We are working on getting pics, DYNO, feedback, etc...
    Jesse
