tuckin steelies
Discussion in 'Stop, Drop & Roll' started by Bulletproofswordsman, Dec 16, 2004.
    Cape Coral, FLorida
    tuckin steelies
    this sorta plays off the last thread but on my 00' ve my rear springs look sagged to the max my stock steelies are almost tucked into the well, ne way i was wondering if you put lowering springs on a car with such a ridiculous sag is it possible that itll be higher than the older ride height? probabbly an obvious question but then again you all didnt become engineers overnight....
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    Well, keep in mind that the rear is lower than the front in general. My rear is dropped almost an inch on coilovers. Here's a pic to give you an idea of how that looks.
    Cape Coral, FLorida
    how much more than your rear is your front dropped and are those full coilovers or sleeves?
    CivicEater Guest
    it's an illusion.. the car can actually be leaning forward, but because the wheelwells are larger up front, it will still look higher in the front.
    teevee247 Well-Known Member
    Montreal, QC
    I had the same problem with mine (still have for a little while longer), ended up having 2 problems, rear struts we're shot and rear strut mounts we're shot. So I ordered new strut mounts, new Tokico HP struts and some Tein H-Tech lowering springs. And I expect my rear end to be higher than it is now once its installed, but my rear tires we're tucking too...
