Engine trouble with oil change
Discussion in 'Powertrain' started by tango, Jun 4, 2005.
    tango Guest
    i made the mistake of draining the oil while the car was on the car ramps and then forgetting to add engine oil before turning on the engine and putting the car in reverse to take the car off the ramps. how much damage did i do to the engine. it was turned on for about 10 seconds. after i realized it, i immediately turned it off and added oil and it seemed to work fine. thanks for any input.
    corollarider19 New Member
    you will be fine
    COROLLA1ZZ New Member
    It might had done nothing to it 10 sec aint chit for it. In my opinion it will be ok
    *sighs*
    you MIGHT be alright...just don't do it again!!
    CorollaULEV Guest
    I am speaking from experience - you will be fine.
    I did the exact same thing with a friend's 1998 Corolla (same engine). Ran the car for about 5 seconds and the oil light wouldn't go off. I revved the engine slightly, turned it off, scratched my head. Started it back up and ran it for another few seconds - realized what I had done and immediatly shut it off. Refilled with oil and started the engine - all was well. No damage done.
    Late,
    Trav
    corolla_man_j Guest
    you did nothing....there was still oil in the engine....all of the oil isn't drained in the pan....that's impossible
    tango Guest
    i posted the original thread. i'm really glad that my car is ok and that you guys are telling me the same. it's an 05 corolla auto with 6800miles. thanks.
