Engine tried to start but only clicks
Discussion in 'Powertrain' started by jcrwzr, Jul 24, 2007.
    jcrwzr Member
    Simi Valley, CA
    your alternator might be dying. from experience, i used to drive a 1991 toyota 4runner. and the first thing to go was the starter... then a couple weeks was the alternator, then the batt. next time, i'm changing those three at the same time. i dunno, that's just me. it also happened to my 1998 chevy malibu. all three in a month!
    i'm surprised the water pump didn't go up around the same time, as well. :p
    DjiNN New Member
    I tried to start my car today. All i got from the engine was a clicking noise. What could be the problem? it was fine yesterday around 7 or 8 pm. This is the first time it happened.
    DjiNN New Member
    damn.. anyone know what the cost might be... would the starter just fail out of the blue ? or is there things that lead up to a bad starter?
    nocpan New Member
    before you go for the starter try to jump start it, clicking noise also is associated with dying battery, I had that happen to me after my alternator blew and I drove on the battery all the way from NJ to NYC with battery dying on me on west side highway.
    So check your battery first.
    DjiNN New Member
    well .. maybe it could be my battery .. but the tachometer lights ex. Check engine, seat belt, and oil lights turn on. Well .. i think i might need a new battery since my system eats most of it up. Sometimes my voltage drops to 11's. i guess i'll see after i get off of work.
    cgreen38 Common sense, p
    Baton Rouge, LA
    I had this happen to me saturday. I replaced the battery (because it wouldn't jump) and it happened again 2 days later. I had to get my starter replaced (the part alone was $200), and now it works fine. I say it's the starter.
    shubert_ae102 New Member
    de mountains :D
    if its a reppetative clicking (like machine gun) its your battery low . if its one single click , its the sylinoid* in your starter , for some reason there common to go on the corollas.
    jcrwzr Member
    Simi Valley, CA
    water pumps are different story. on my old ae92 my water pump seized and the belt snapped. that caused the radior to go bad... then that casued the cooling and oiling system to go bad... it was a chain reaction...
    but.. yeah, back to the ignition and starters
    DjiNN New Member
    Its my battery .. had it replaced and now everything is fine
    Baton Rouge, LA
    Get your starter checked, too. I replaced my battery Saturday and my car was fine until Monday night. Then the clicking came back and I could only start the car by pushing it really fast and then popping the clutch.
    In short: GET YOUR STARTER CHECKED.
    de mountains :D
    hahaha as all corolla starters do:D
    DjiNN New Member
    hopefully it wont die ...
    best of luck
