Trial By Fire: Toyota to run nearly stock 2010 4Runner in SCORE Baja 1000
Discussion in 'Auto News' started by Autoblog, Nov 10, 2009.
    Autoblog Guest
    Filed under: Motorsports, Performance, SUV, Toyota, Off-Road
    2010 4Runner for the Baja 1000 -- Click above for high-res image
    Toyota is taking a nearly stock 2010 4Runner to the Tecate SCORE Baja 1000 in about ten days, and the immortal Ivan "Ironman" Stewart will be piloting. Toyota hasn't said what changes to the production truck will be made, but the class rules dictate that runners stay pretty close to factory specs, while allowing more serious mods to the suspension and whatever is needed inside for a safety cage.
    In addition to the loss of the rear gate and the swapped-out wheels, we imagine a thorough shock overhaul and a minor engine tune. We'll look for more in-depth info on the car as the race gets closer, but for now we'd like to let Toyota know that they need to add this package -- minus the cage and spare -- to the 4Runner's showroom offerings. You can read about the truck in the presser after the jump, and click above for a high-res image or check out the stock '10 4Runner in our gallery below.
    Gallery: 2010 Toyota 4Runner Limited
    [IMG][IMG][IMG][IMG][IMG]
    [Source: Toyota]Continue reading Trial By Fire: Toyota to run nearly stock 2010 4Runner in SCORE Baja 1000
    Trial By Fire: Toyota to run nearly stock 2010 4Runner in SCORE Baja 1000 originally appeared on Autoblog on Tue, 10 Nov 2009 17:58:00 EST. Please see our terms for use of feeds.
    Permalink | Email this | Comments
    More...
    i wouldn mind having one of these as my daily driver.
    Phan Well-Known Member
    Orange County, CA
    great for going over parking lots rail
    Ares Active Member
    Houston TX
    They should make the engine waterproof. The Philippines would need some of these for disaster relief after tons-o-storms hitting.
    its_ikon FIRST widebody
    Henderson, NV
    every since driving one of these at sema i have started to really want it. i just can't see spending 40k for the trail edition.
    that is when you get a snorkel.
