Engine TRD vs. TWM short shifter
Discussion in 'Powertrain' started by Ninety Four, Dec 19, 2006.
    Which one is better?
    Also, I know the TRD setup replaces the whole shifter assembly. How does the TWM compare and what does it include?
    cgreen38 Common sense, p
    Baton Rouge, LA
    I have a fidanza shifter, which is almost exactly like the TWM (only like $80 cheaper). It came with solid bushings for the base, and it works great. The only other part you'll need to buy is an e-clip (just go to autozone, they're cheap). Total install time for me (I took my time with it) was somewhere around an hour.
    What year is your car?
    rayray1 Active Member
    it says so right under his avatar...... 98 Corolla VE
    You must be using the TRDstyle color setup for the board. That text doesn't show up for some reason in the Dark Blue color setup..
    Baton Rouge, LA
    Yeah. I use the TRD color scheme. :p
    Javidawg19 New Member
    West Palm Beach FL
    How Much Is A Fidanza Short Shifter?
    Baton Rouge, LA
    Mine was about $50 shipped. Look for 00-05 Celica GT shifters on eBay.
    i recommend geting some shifter bushings as well.. improves shifting feel dramatically and replaces those worn out rubber bushings.
    http://www.speed-source.net/
    West Palm Beach FL
    i found a fidanza for $61 and shipping for a celica gt. apperently it fits.
    Baton Rouge, LA
    Good deal.
    ZZcorollaVV_Ti 04 corolla
    Daly City, CA
    there was something about twm not being a "true" short shifter and trd being one. Ill try to dig up the thread, but this was in regards to 03+ corollas, and i guess you have a 94?
    Silver Bullet New Member
    I have the TRD. It is becoming notchy and grinds especially going to 3rd gear occasionally. Is this normal or is something wearing out? I installed it about 20k miles ago.
