Wanted TRD Supercharger 1zz-fe
Discussion in 'Wanted: Car Parts' started by Yinster, Jul 18, 2014.
    Yinster Well-Known Member
    Hawaii
    looking for a used trd supercharger for 1zz-fe
    the best will be include all the wiring needed for install
    thanks
    also looking for TRD spring as well
    technically all the wiring needed for install would include a full conversion to a 9th gen ECU setup, then all of the TRD piggyback stuff that comes with the supercharger kit.
    With that being said, what is your budget? I have a complete kit, +2ZZ yellow top injectors, with a standalone ECU (Power FC, commander, Datalogit) and J&S Safeguard (separate timing controller/high speed knock monitor/detection setup) that I could part with for the right price.
    Hawaii
    hey james, i just pm you for some question...... actually i am just looking for kit only, cause i want to stay oem, and start prepping my car in case i am coming to the great state of califronia with my car, which will face smog test once it lands on port of los angeles lol
    Not looking to part with the kit only, since the parts are pretty specific.
    By the way, the kit itself, the way it comes from TRD, will never plug into any 98-02. The only way for it to be legal in California, is to convert your car to 9th gen electronics, BAR it that way, then install the supercharger kit. Only way it will be legal and work. The TRD piggyback is not designed for the stock knock sensor setup in 00-02 1ZZ Corollas and will not modify timing as needed.
    Jugs McBulge likes this.
    Hawaii
    ok james, thanks for the feedback, i will let u know once i come to my decision...... wonder whats the price in ur mind
    so, i assume full swap to 9th gen ecu and stuff is needed in order to be legal in CA..... ok thanks man
    What a pain in the ass.
