Engine TRD Strut Tower Brace
Discussion in 'Powertrain' started by trdalm, Apr 22, 2004.
    trdalm Guest
    Has anyone installed a strut tower brace on their car? Is installation easy? do I simply remove the nuts and place the brace in its place? or if I remove those nuts will something from my engine fall down or something? do I need a machine to tighten it or can it be done by hand?
    thanks
    White Rabbit Guest
    Yes something from ur engine will fall since its connected to ur engine. :lol:
    J/K
    All u need is a wrench I forgot the size but
    Just unbolt the 3 bolts on top of each strut make sure ur wheels are straight and car is on the ground level. then just put the FSTB on top and bolt them down. Ur suppose to torque them down to a certain amount im not quite sure, but theyre around the site somewhere.
    hooolala Guest
    Re: TRD Strut Tower Brace
    lol.... yea.. is very easy... just like you said, removethe nuts, put the strut bar on, and lock it..
    don't worry, nothing will fell off.. (as long as you DON'T left your car up when you are working on it..)
    trdalm Guest
    thanks guys..
    was just making sure.. better safe then sorry!
    I found that they should be torqued to 29 ft - lb. How do i do that? is their sometype of cheap gadget that measures how much ft - lb. is?
    White Rabbit Guest
    Yes A torque Wrench u can buy or just borrow/rent one from ur local auto shop **Advanced auto parts, Auto Zone, Pep boys,** they might even help u install the FSTB!!! :D
    m_a_b Guest
    those wrenches are not cheap, tho. My craftsman torque wrench cost about $75. Borrow one if you can, unless you plan on working on your car a lot.
    brownbanana ToadMotorSports
    Oahu, Hawaii
    even if something did fall down, it wouldnt be anything from the engine because the bolts connect to the strut assembly, it would be from the suspension. but yea nothing will fall..i believe the size was 12mm if i remember correctly.
