Engine trd quickshifter
Discussion in 'Powertrain' started by gridjockey, Nov 21, 2006.
    gridjockey Well-Known Member
    glendora,ca
    trd quickshifter
    recently found that the quickshifter for the scion tc will work in a corolla xrs.shifter comes with base and solid bushings for the mount along with the shift knob. shop around i've seen it as low as 230 dollars american.looks like about a 25 to 30 % throw reduction.the pt. no. is PTR04-21051-40. the shifter hight is not as short or as low as the twm shifter,and you don't have to ream out the plastic ring at the top of the boot.
    cgreen38 Common sense, p
    Baton Rouge, LA
    I've got a Fidanza unit (repackaged and put on eBay without the sexy shift knob :( ) with solid bushings, and I love it. Wouldn't even come close to considering using stock again.
    glendora,ca
    i'm using the twm shifter and i like it alot. just beaware that it is esential to use the two metal clips for the cover over the ball and shifter rod.
    Baton Rouge, LA
    werd. Those clips are evil.
