Engine TRD muffler . . .
Discussion in 'Powertrain' started by Darkness, Aug 12, 2004.
    Darkness Guest
    TRD muffler . . .
    a few questions. . .
    What size piping does the TRD muffler have?
    Is it possible to get custom piping and still keep it a bolt on muffler?
    and will the muffler get louder?
    slvr2000fdvspec Guest
    i think if you get custom piping, it would get louder, i'm not sure..
    Darkness Guest
    I'm pretty sure it would get louder. but you think it would get really loud? Like "pull his ass over cause it's soo loud" loud?
    well depends i guess on muffler, my friend has a custom 2.25" catback piping with a magnaflow muffler, oval type on an integra gsr, that thing is LOUD, he got harrassed by cops so many times about it, he just pops it in neutral whenever he see's a cop and keeps it there for about a block
    Darkness Guest
    I just want he TRD muffler because it's not even loud, but I was wondering if I do get custom piping will it get loud enough to get pulled over :( . and I was wondering if anyone knew the size of the piping on the TRD muffler. . .
    that's cool..i might order a catback from alpha werkz and use their catback piping, and put it on a trd muffler, i'm not a fan of those big oval mufflers lol, only reason i had one on my SI was cause it was for 150 bucks and it was a catback =P
    Darkness Guest
    you think it would perform decent with the TRD muffler?
    nah , it won't be that much louder. just make sure you get a resonator put in right after the cat or it will sound very high pitched and shitty. it doesn't matter, you don't have to match pipe sizes .. what you do is you get the muffler and tell them you want custom piping to fit the TRD muffler and they will put an adaptor on before the flange to match the piping size and it will bolt on fine.
    so basically a trd muffler would bolt on to any catback piping?
    yep, as long as it has the correct matching flange.
    COROLLA1ZZ New Member
    Darkness Guest
    sweet thanks for the info guys :D
    blancokracker Guest
    Our cars DO NOT sound high pitched, shitty depends on your opinion though...Meaning if you don't like the firing order of a 4 cylinder which produces that flapping sound, then yes its sounds shitty. I wish I had a camera with sound to let you hear it right before the resonator.
    Supershyguy New Member
    yes it will be louder with custom piping
    d_samurai Guest
    the trd muffler does an excellent job of creating a sweet sound, but at the same time, keeps the decibles down alot...mostly b/c of the shape of the muffler and the internal walls..but put an ebay muffler on the end=an oval bullet shaped, and yes..its obnoxiously loud...
    yea it'll perform decent.. about the same as the stock muffler, give or take :D
    RollaRyder1103 New Member
    Corona, CA
    i have the alphawerks cat-back piping and just put on the TRD muffler last week cuz I needed somethin legal...the alphawerks exhaust sounded really nice and deep...but a cop didnt like the loudness 4 some reason...I was parked! so dont know how that went down...but they dont have a CARB #, so I had 2 swap 2 somethin legal....so I left the alphawerks piping and slapped on the TRD muffler and it's not loud @ all...the only thing u have 2 do is cut off the part that sticks out on the end of the flange...it should come off cleanly with a hand saw and a lil force...the intake is louder now IMO...but I'll give a def answer after I get some new valve cover bolts and replace my valve cover gasket and I'll get some vids w/ sound on here 4 u guys.
    d_samurai Guest
    so you did some custom welding with the trd muffler? where did you get the hooks to hang onto the rubber hangers?
    Corona, CA
    no welding...straight bolt ons....i bought a couple of different exhaust hangers from autozone and wallah.
