TRD Lowering Springs. Need Help.
Discussion in 'Stop, Drop & Roll' started by |-Goku-|, Apr 25, 2009.
    I need some help. I want to know if I would be able to install TRD Lowering springs with my room mate in a garage, with the car on jack stands.
    Here are the instructions,
    http://trdsparks.com/install/PTR40-02080inst.pdf
    Any help would be awesome!
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    The only problem I would see is using a spring compressor. And DONT use the ones that arent mounted securely to a wall or stand of some sort. Youd be amazed how far those things can shoot under pressure if you make a mistake.
    Also it would probably make life easier if you guys had an air compressor and air tools. Espically when tightening the nut back onto the top of the strut.
    Good luck!
    SaberJ2X Lurk MOAR
    Mayawest, PR
    I'm with karma, I've seen spring hitting ceilings once, scary shit xD
