TRD Lip Kit HELP!!!
Discussion in 'Exterior' started by Mayur, Feb 3, 2007.
    Des Plaines, IL
    TRD Lip Kit HELP!!!
    Alright I just car back today from the shop. It was supposed to come back with the kit installed but he didnt do it. He said that the kit would start to bend because of the cold. He told me that this kit cant be used in the winter and Im calling a major b.s. on that. Vamp is in Maryland or around there, CB up in WA. Colder over there than here. So now I have my entire kit painted but it needs to be installed. Not sure if he drilled the holes yet or not so I gotta check. How difficult could it be? I know about vamps diy but Im kinda quesy. Also is he yanking my chain or something? I deff do not believe him about it bending from the cold. Either way hes mad at me because of it lol. I dont even like him but hes my dads friend...
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    hmmm that's odd
    Des Plaines, IL
    I dont think its odd, I think hes just an ass. One of the side skirts seems a little out of shape but I was bending it earlier and nothing was going wrong with the paint or anything.
    interestingg....good luck with that. did you get that trd trunk lip spoiler(blue)?
    Des Plaines, IL
    Yup
    painted/installed it? i got mine in the same color of my car :D
    Des Plaines, IL
    Everything has been painted now and its all blended too because whole car was repainted. Nothing is installed because of the douche bag of a mechanic I got.
    Ok this ass is now telling me that he took it to the Toyota dealer and they told him that they discontinued the kit because they would never fit right. Im about to slap this asshole.
    It's true that the kit doesn't fit perfectly because one of my side skirts is slightly too short but I stretched it.. and one of my front lips is longer than the other by almost 1/4"
    as for the cold.. I installed mine when it was 85 degrees outside and it has since been in 5 degree weather and hasn't really flexed at all. The weather part is BS. Installing the kit myself took around 3 hours but I was being really careful about lining things up too.
    so basically that "mechanic" is just lazy and doesn't want to do it for you?
    gotcha.
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    I would wait till it's warm out before installing it. I've had the paint crack and flake off my kit when the pieces are flexed because of the cold.
    Des Plaines, IL
    I can understand it cracking but he was telling me the paint was coming off like paper. Hes just really lazy. I have no choice but to wait until it gets warmer because right now Im off from school because of extreme cold temperatures lol.
    Rosedale, MD
    That's actually what happened with mine. It cracked and the paint just came off like paper. I could probably peel most of it off if I wanted to.
    Des Plaines, IL
    Hmm so maybe he wasnt lying...
    the paint comes off like paper because you're using a regular paint on a FLEXIBLE, POLYURETHANE part. the original paint that came on the trd lip kit was flexible just like the part, and when you twisted, bent, pulled it, what have you, nothing happened.
    Des Plaines, IL
    So regular paint cant be used on this? It has to be some special paint?
    plu Well-Known Member
    SC
    my kit never had that problem with the paint peeling. I had it since 2001 been through 20 degrees to 115 degrees weather. it has the orignal paint though.
    Des Plaines, IL
    20deg is nothing compared to what are getting here. This morning it was -12 without the wind chill and currently its at -2
    Rosedale, MD
    I had that flex stuff on my paint job as well, but it still peeled off anyway, and it's not like I got a cheap paint job done on them.
    laz Member
    NYC
    When I had mine the driver's side skirt would shrink when the tempetature dropped below 30 F. It would shhrink so much that it would pull the fender into the door and have the door rub the fender whenever the door was opened. I had to make a cut on the seam to fix it.
    My kit was repainted as well professionally, and it never loss any paint. Is the same paint they use on bumpers.
    your mechanic may actually be smarter than you think, he does not want to deal with you coming back to him bitchin' that it does not fit well and that it is his fault.
    X
    Des Plaines, IL
    your probably right about the bitching thing but hes still stupid. hes the ass that uses epoxy to stick on emblems. epoxy + paint = bad :( i know from experience from this ass.
    lol why'd you go back to him after the epoxy incident?
    tsburt Active Member
    miami
    LOL..makes u wonder huh
    Des Plaines, IL
    Well he had smashed my bumpers so he was gonna fix em. I thought since he was already painting half the car, might as well do the rest with the lip kit :p
