Engine TRD Flywheel & Clutch
Discussion in 'Powertrain' started by sxlostv1, Nov 10, 2004.
    sxlostv1 New Member
    Los Angeles
    fidanza flywheels cost less i think
    Barnacules 100101101011011
    Duvall, WA
    I want to go with a 10lb flywheel in my 2001 Corolla and I know that TRD has one but i don't know of a good place online to buy it is. Anyone have any idea's? I'm also looking for a real good clutch that is driveable but way more sticky then the stock clutch. If you know of a good reputable dealer online that sells what I'm looking for please let me know.
    Thanks...
    Montana Guest
    Mike, I know a good place to get a flywheel machined.
    mncrolln Guest
    you should also check out vpower.net and monkeywrenchracing.com
    polo708 New Member
    9thgencorolla.com
    monkeywrenchracing.com makes a fllywheel, its not TRD but is probably better and cheaper.
    toyotanut3717 Guest
    jpbartosch Guest
    Ultrarev.com has the best pricing I've seen
    Look at Fidanza flywheels and an ACT clutch here http://www.ultrarev.com
    The Fidanza flywheel is 8.3 lbs. and is significantly lower in price than a TRD flywheel.
    CadetLee Guest
    I have a Fidanza flywheel (9lb 1.5oz) and ACT HD clutch -- I love it.
    --> www.monkeywrenchracing.com <--
    Duvall, WA
    Well it happened, My clutch blew up today. If I stop the gas to the floor it just slips like a bizzatch. I want to get the Fidanza Flywheel and the ACT HD clutch. Does moneywrenchracing.com ship fast because I need the clutch and flywheel ASAP. Also do I need to have the flywheel ballanced because someone told me that fidanza's are not ballanced or something ready to install but that might have been a load of BS.
    Thanks...
    baddrunk69 Guest
    You might have bought them already but I was planning on purchasing the clutch from
    https://www.prostreetonline.com/store/drivetrain/ for $300 shipped for a HDSS
    you have to look it up by model number. our corollas use TC2 and it comes up with it for a celica. They don't even have it listed for corollas.
    and the flywheel from monkeywrenchracing as they pricematched with ultrarev for 359+8s/h
    CadetLee Guest
    I didn't have any problem with MWR's shipping..if you order a clutch and a flywheel, they might cut some $$ off for you -- ask them about it =)
    I have never heard about balancing a flywheel. What's to balance?
    Duvall, WA
    I'm talking with MWR right now trying to get a total quote on an ACT clutch and Fidanza Flywheel. I hope i can order it soon though because my clutch isn't going to get me to work in a few days :)
    Duvall, WA
    I just ordered my parts, I went with the XTSS because I want the most driveable hookup I can get since I'm going to boost next.
    Just placed order today at UltraRev.com, Prices aren't bad lets see if there service is up to par :) I need these parts by Friday of next week so my friend can install them on his day off.
    ACT 2600 Clutch Kit Toyota Corolla 6/92-00 1600/1800cc 212mm (Torque Capacity:( 275 (Pressure Increase:( 65% (ACT Pressure Plate:( T-022X (ACT Disc:( TYSD035S (Release Bearing:( RB840 (Pilot Bearing:( N/A (Alignment Tool:( ATK73
    Note: Image shown may not be for your specific vehicle.
    Item #TC2-XTSS 1 $387.50 $387.50
    Fidanza Aluminum flywheels Toyota Corolla 98-03 1.8L FWD Weight: 8.5 Code: TO14
    Item #130231 1 $359.00 $359.00
    Power Slot Slotted Rotor TOYOTA 1993-2002 COROLLA FRONT LEFT ROTOR
    Item #741PSL 1 $76.13 $76.13
    Power Slot Slotted Rotor TOYOTA 1993-2002 COROLLA FRONT RIGHT ROTOR
    Item #741PSR 1 $76.13 $76.13
    Hawk Performance HPS Brake Pads TOYOTA COROLLA 2002-98 Front
    Item #HB321F.650 1 $61.10 $61.10
    Product Cost $959.86
    Shipping Cost $72.11
    Coupon Discount ($28.80)
    Total $1,003.17
    CadetLee Guest
    Good luck with the install -- FWD clutches are annoying. I ended up paying someone to do mine..then again, I couldn't have it apart for more than a day...and I'm not a mechanic. :p
