Engine TRD ECU
Discussion in 'Powertrain' started by rudwn4a69, May 9, 2004.
    rudwn4a69 Guest
    TRD ECU
    Anyone know where to find the TRD ECU? And how much? Also, if it's recommended any downfalls, performance gains, etc. THANKS!
    hooolala Guest
    you can get it from toyota for about $900
    but.. why do you need it?
    lonelydriver New Member
    Would it even be any use without the supercharger?
    RollaS New Member
    no it basically controls the 5th fuel injector
    tom Guest
    It works in conjunction with the Stage 3 TRD Supercharger to compromise air/fuel ratio and boost control.
    dominator 04 Rolla 5spd.
    tom Guest
    I think it was Crovax who has the Greddy e-manage setup for his turbocharged Corolla. Greddy claims that it can reprogrammed anytime you add additional mods to the car, so that's good, and they are a reputable company too. I wouldn't worry about getting the TRD ECU, unless you have the TRD Supercharger. It's pretty much useless in other application as it is proprietary. It uses the Corolla's air'fuel map and spark timing to help regulate extra "power" produced by the supercharger.
    alpha-vvti Member
    will this help much if i only have intake, header, and exhaust mod?
    White Rabbit Guest
    Could the TRD S/C work with the Greddy E manage, instead of Using the TRD ECU or UNICHIP?
    tom Guest
    I'm going to contact TRD about those questions. First, if it will compensate for the added mods (headers, intake, etc.), and second, if an aftermarket computer will work with the supercharger.
    I'm sure they'll say that those kind of work will automatically void warranty, but I'm curious if it will work or not. I'll have to post later once I find out. I remember someone (I forgot who it is) on this forum had an intake put on with the supercharger and didn't run that good. As far as headers, some people say that headers are beneficial with the supercharger. I wonder how the TRD ECU will react to mod?
