Engine Transmission differences?
Discussion in 'Powertrain' started by Dr Tweak, Mar 9, 2005.
    Dr Tweak Mad Scientist
    Savannah, GA
    Does anyone know the 5-speed transmission codes for the '93-'97 Corolla and the '98-'00 Corolla? Are they the same?
    teevee247 Well-Known Member
    Montreal, QC
    C-50 for the 4AFE and C-52 for the 7AFE in the 93-97, not sure about the 98 +
    I believe 98-02 are the same for transmission code. I'll try to look and see if I remember.
    Savannah, GA
    If you could that'd be great.
    killer2239 Lift at 5700rpm
    Lexington, KY
    i dunno if the code is the same, but i know they use the same tranny as the 7afe, for the 98-02
    Savannah, GA
    That means that the 2ZZGE is a direct swap for all '93-'97 Corollas as well, as long as you keep your stock tranny. :)
    i'm not too sure about that - i'll see if I can't dig the bizzitch up tomorrow before i get too into the day - i was gonna do it tonight but i had to go stomp some honda bishes so I was busy.
