Engine transgo auto tranny mod
Discussion in 'Powertrain' started by sean2sean, Mar 4, 2009.
    sean2sean Member
    so cal
    its been a while.... but i thought i bring it up....
    if you have an auto and want faster fimer shifts... look into the tranny mod.
    transgo.com.
    here is the part number.
    A245E-HD2
    NEW
    Corolla 93-02
    Geo Prizm 93-01
    Corrects: Soft 1-2. Long 2-3 at heavy throttle.
    Firmer 4th and Lockup. Designed for Nitrous or
    JOE85 New Member
    im curious about this as well, as of no i have no near future engine high hp mods, maybe later on doing a 7age hybrid. but im curious how this would affect the reliability of the trans and would it still be good for daily driving
    btw sean i pmed u back, i got the email
    Yeah, I brought this up when Dr. Tweak started selling them a while back. I don't see a point to add them to our cars since they don't make that much power anyways unless you're forced fed. It would be a great addition to IS300's, G35's and the like though.
    sean2sean Member
    so cal
    well im not f/i anymore... im stock n/a.
    i daily drive my car with stop and go traffic...
    and the shift kit works very well. much better shifts compared to oem.
    there will be less wear and tear on your transmission. because the shifts are shorter... and less heat. check out transgo. and read about if you are curious.
    i think it cost 100 for the kit.
    FYI, judging from the part number, those will only work on the 4 speed auto. Could be wrong though.
    So it's installed in your car? Were there any extra costs to install? Bottom line is how much did you spend in total to put it in including the cost of the transgo? And where did you get it?
    JOE85 New Member
    so basicly if you dont have a 4afe your good cause its the only one that has a 3 speed auto, k i dont have that so im good
    teevee247 Well-Known Member
    Montreal, QC
    The 1ZZ-FE also came with the 3 speed auto for a few years... can't remember the specifics though.
    sean2sean Member
    so cal
    i have it on my car right now. and i am driving it without turbo.
    i have a automatic. 4 spd. auto.
    kit cost 100. give transgo a call and see whats up.
    thats all you need... install the parts and your ready to go.
    You can do the install yourself with hand tools? I'm guessing it takes around 3 hours like the site says.
    sean2sean Member
    so cal
    Yea just with basic hand tools n a jack.
    Took me 1.5 hrs.
    Drop tranny pan. Install parts. Put pan back. Fill up tranny fluid.
    darkgamer1912 Member
    CT USA
    so is it worth it to get it cause my tranny shifts real hard now would this solve the problem somewhat or should i not bother
    ^^^ Tranny shifting hard might be from something else, i.e. gum, deposits in the transaxle, maybe not frequent enough transaxle oil changes for the type of driving it experiences.
    sean2sean Member
    so cal
    shifting hard is something else.
    this kit firms up the shifts.
    if you notice stock tranny. 1 to 2 and 2 to 3.... there is a small delay between shifts. this kit takes that away. and shortens the shift.
