Engine Tranny
Discussion in 'Powertrain' started by 4arolla, Sep 16, 2005.
    4arolla Well-Known Member
    Tranny
    92 corolla wiht 170000 miles. Tranny is has problem reversing. When put in Drive it goes but when in reverse it seems to not wat to move, It does but feels like its not catching and feels like its slipping. Is it the tranny or the torque converter.
    thanks
    mike
    JLee TD05 3SGTE
    NH
    Have you checked the tranny fluid?
    I know on domestics the tranny shifting bands can become misaligned over lots of miles/time. Usually you use a special tool to align the gears again so it shifts correctly.
    fluid is ok and everthing works. I just not sure if its the tranny or not becuase it drives fine. Its just when you put it in reverse it has problems.
    01rollas New Member
    your tranny is giving out and the internal bands/belts my need replacing and it should be fine and last another 170K miles
    Dr Tweak Mad Scientist
    Savannah, GA
    I've got an auto tranny from a '97 Celica here, it'll probably work for you if you want it cheap.
    -Doc
    01rollas New Member
    he's got the knowledge so get the tranny i think ur better off getting another one. and its Dr. T so he knows what he states.
    Dont want to convert it to a 4spd. that measn i need to get the harness and control module and all the other stuff. If do change it i just keep the 3spd auto.
    01rollas New Member
    its your choice check to see if its even a 4 spd! i am sorry i am drunk right now.
