Engine Tranny Noise
Discussion in 'Powertrain' started by KonigRolla, Sep 7, 2004.
    KonigRolla New Member
    Tranny Noise
    okay well my rides got a lil over 150k miles on it ( automatic ) .. and when im riding down the road .. and let off the gas completely then get back on it .. it feels as though the tranny is slipping i guess uyou could say .. like i hear a lil knock sound right when i get back on it .. and thats not gunning it .. just back on the gas normally ..any ideas as to what it is .. someone told me i need to change the tranny fluids , but other than that noise .. its drives fine .. no loss in power , no missed shifts , or drowned out gears ..
    also i know this isnt the correct thread but i aslo have a question about a major vibration im getting in 2nd gear ..the car shakes .. almost all the way through second gear .. what could that be ? ive thought maybe it could be a bent rim , bad strut ,lose strut, maybe my mufflers causing the vibration .. but it even vibrates in the steering wheel .. any ideas ??
    thanks in advance ..
    03silverrolla Guest
    I had the service done... I even had the valve body flushing done..... What i might do and what you might want to do is maybe get the throttle valve cable (TV cable) replaced.
    03silverrolla Guest
    im getting that same feeling with my auto 98 corolla. I have 116k miles. Seems like sometimes when Im in second gear and it wants to downshift into 1st gear it seems to want to slip into first gear. But I dont get a noise though.
    The transmission should have the fluids drained and refilled at least every 60K miles. I generally go about 30K and do a drain and refill, drop the pan and clean out the filter and magnets in the bottom of the pan - since i sometimes drive a lot of stop and go and pull a trailer.
    The knocking noise, when you get back on the gas, could be CV joints, loose/worn suspension components, or transmission/motor mounts that are worn or loose. This would also tie in with the vibration that you feel in second gear.
    That feeling of slippage is hard to overcome - automatics just operate that way. Going to a synthetic ATF may help with internal noises and help smooth out the shifts.
    If the fluid hasn't be serviced - might be a good idea to have it done just to see what will happen.
    Good Luck.
    Something like that happened to me.. Something on the axle were loose.
    BTW are u still intrested in the Tom's Spoiler?
