Touchscreen LCDs
Discussion in 'Interior' started by flavious27, Feb 12, 2004.
    flavious27 Guest
    WebMasta33 Guest
    The question "where will if fit" can only be answered by asking "where do you want to put it".
    Realize thought that the Touch function can only be used by the USB cable hooking it up to a computer. Which means that you'd have to install a small computer somewhere in your car.
    DaChozn Guest
    Looks like it may get a little complicated to put that in. I know of some flip ups that come with the touch screen option, you may want to look into that.
    flavious27 Guest
    flavious27 Guest
    I want to either have the pc installed in the trunk, or in the middle compartment where the armrest is.
    Sasuke Guest
    thats sweet how he did that to the Audi it can be done flavious27 good luck on it hope to see some pics when ur done
    DaChozn Guest
    Wow....that's impressive, it has that near perfect stock look to it and the computer is awsome. Too bad it doesn't have a DIY. If you manage to do this is in your car make sure you post some pics.
