Engine ??? to people who done the 2zz swap
Discussion in 'Powertrain' started by VTEC-KILLER, Oct 13, 2004.
    VTEC-KILLER Guest
    i need to know if the engine mounts fit fine or if i have to get custom mounts made, thats the only problem i got to solve, to start doing the project myself.
    im about to buy a whole 2005 Corolla XRS totalled from an insurance company for $1700. going to pick it up tomorow
    02RSX Guest
    i don't think anyone other than pete has successfully completed teh 2zz swap.
    WandrerX New Member
    there was the other dude... miniyota... he did a lot of it himself... one of the first to do the swap I believe... his corolla is gone now though
    killer2239 Lift at 5700rpm
    Lexington, KY
    supershyguy did.
    LoSx New Member
    supershy doesnt know jack cuz shop did it for him probably!
    Uhmm if its a corolla xrs maybe that 2zz has different mounting points then other 2zz?? it may just go in..... oh but you dont have an 03+ do you??
    Last I heard it does and dopesnt... some do and others needed to be made
    VTEC-KILLER Guest
    i got a 2001 Corolla
    Only $1700? That's a very good deal!
    And you should get the rear disc brake too!
    Drummer426 Guest
    i can't believe someone already totalled a xrs already!! now there are only 4,999 units in america now
    Turbo1zz New Member
    The motor and tranny will drop right in... There are going to be a multitude of other problems you are going to have to worry about though.
    Make certain you get everything as this will increase your chances of success. The engine mounting points are the same for the 1zz-2zz family. The Corolla XRS is using the same motor as the Celica GTS and the Matrix XRS and these have been proven to fit in place of the 1zz. If you are installing this into an 03 or newer Corolla, then it should be a farely plug-n-play operation. If you are not and your car is older than 03 then "good luck", It's going to be a good deal of work but it will work and the motor will fit...
    02RSX Guest
