Engine tips on winning.
Discussion in 'Powertrain' started by sxlostv1, Jan 31, 2005.
    sxlostv1 New Member
    Los Angeles
    tips on winning.
    i have a 01 corolla with nothing really done to it. Just trd muffler and removed air reservoir. My friend has a 96 civic EX (vtec d16y8 motor) completely stock. My friend and i test our cars against each other on a straightaway and this is what happened. I had him on the launch, 1st and 2nd gear, and he just takes over by about 1/2 a car after that. What can i do to make my car even the slightest bit faster than his?
    Dr Tweak Mad Scientist
    Savannah, GA
    Well, you can do the basics, intake, FULL exhaust, lighter flywheel, etc.
    (Have a look at www.monkeywrenchracing.com)
    If you want some serious power that will really make a difference, you need either N20 (cheapest and quite reliable if done right), or turbocharged (also reliable when done right, but not cheap).
    teevee247 Well-Known Member
    Montreal, QC
    Do you have any extra weight in your car (sub, tools, people), if so, try removing them next time your race him. Try getting a true CAI (like the E.L. Prototypes), also, maybe just do a good general tune-up on your engine. Or you could always buy a nitrous system, and right when he is about to pass you...
    Cape Coral, FLorida
    i can see it now every1's gona tell u to get a new car, or to just give up.....
    neway i say weight reduction, take out your rear seats and gut the trunk, see how that works out for you.....
    JLee TD05 3SGTE
    NH
    Auto or manual?
    Clutch/flywheel may help your launch/shifting a little...exhaust will help out the mid-high end..and better tires can do wonders for your launch, too.
    Out of four people replying so far, you're the only one to mention that...lol :p
    RollaRyder1103 New Member
    Corona, CA
    Kenny...do what they are saying and it should help...ELP CAI, lightened flywheel, better tires, remove spare and jack, remove system in trunk if any, and learn to shift better...know when your peak power is, redline mostly is not the heart of the HP/TQ
    n00bie MODACAR
    nor cal
    this is where the saying goes..m4d 3rD geaR vtak y0
    TheTruth New Member
    ConnecticuT
    advance your timing hehe
    Mike4831 C-Town Pimp
    Statesboro, GA
    What is the fasination with beating a bone stock Civic?
