Tinted red tails
Discussion in 'Exterior' started by rainbow_star, May 28, 2007.
    Post some pic! How did you tint it? clear spray paint?
    Tinted red tails
    I finally got around to tinting my tails red. Turned out pretty well. So now the outer tails are red and the inners are red and form a clear halo at the edges. It looks hot. I'll post pics later. I also tinted my extra inners full red so I can switch back and forth between styles if I wish.
    jdmikey New Member
    nice. post pics when u can
    I used red vinyl tint. It took me a couple tries to learn how to apply it correctly. That was annoying. LOL I tried to do what mingww in trdforums did but the inner tails came out horrible and I had to remove the red. I'll try to do it over later.
    mingww
    Here's what I have done so far...
    btw don't you think the chrome exhaust tip distracts from the flow of the car? I'm gonna primer and black it out when I have time.
    SD_S New Member
    SF, CA
    I always wanted to do what mingww did also with his inner tails. Can't wait to see your result.
    jdmikey New Member
    lookin good. and yea that vinyl is tricky to put on. took me a couple of tries before I got it right.
    The secret is soapy water and heat. LOL
    Wow that looks hot, very professionally done! Good job man.
    And I think the chrome exhaust tip is cool btw. :)
    Too late. I painted the exhaust and tip black now. hehe It looks really hot. I'll post pics later.
    fuzionrolla Guest
    vinal is fun stuff i have a plotter so i cut a bunch of vinal
    Making the templates for the vinyl pieces were hard and inaccurate. Its really hard to make one for the mingww inner taillight halo look.
    shubert_ae102 New Member
    de mountains :D
    so thats where to find it , ive looked every where for the tinting spray , so i can do mine. is it for lexan r/c cars? how many coats did you put on?
    robert_nuray Guest
    that does look good but i just used tinting spray from a hobby shop and they are a lot darker though, maybe i should have gone with the red vinal as well
    808trd Guest
    where did you get the vinyl if i may ask=D
    I say use vinyl tint since its reversible. Once you use spray and if you screw up or don't like it anymore, you're screwed.
    10R New Member
    You guys have it easy compared to Prizm tails! But rollatuner is right about getting it done well. Heat with a hairdrier takes out all the bubbles. Did you use Oracal 8300 red vinyl? Thats what I used. I put it on 3 years ago and it hasn't faded, cracked, or anything. Looks as new as the day I put it on.
    de mountains :D
    not nessacarily , denatured alcohol will pull it right off. then you just buff your tails , and viola , back to normal , stock , and shiney.
    I just think vinyl is cleaner and easier to use. You can peel the the vinyl right off with no residue if you don't want it.
    94 rolla Guest
    theres also stuff called VHT nite-shades. they have black out and red out. i got mine at my local tuner shop, so if you guys have one around and want to do it, just ask them. only problem i had with it is that on the first one i did i cleaned it before i did it with some headlight cleaner and it made it extremly bubbly. fixed it they look good
    de mountains :D
    rolla tuner , you gotta think though , 7th gens got those 2 creases running longitudal across the tail lights , there deep , tint isnt gonna form into that and look right . it may be easy on you guyses year models , but i wanna see it a 7th gen , before i buy the vinyl.
    de mountains :D
    You can cover the whole taillight and make slits in the vinyl to make it fit snugly. Its not that much harder.
    de mountains :D
    hmmmmm.
    10R
    i know the prizm tails like yours , have these little slits im talkin about , how hard was it?
    de mountains :D
    10R New Member
    Just cut the film a little big and then when you heat it, it will shrink down and form in the slit. I have maybe one or two tiny bubbles there total for both lights, so it works pretty well.
    de mountains :D
    cool , where can i get the vinyl , or is it the same as window tint film?
    808trd Guest
    i'd like to know also
    I got mine from ebay. It works fine.
    <a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;ih=007&amp;sspagename=STRK%3AMEWN%3AIT&amp;viewitem=&amp;item=170092140751&amp;rd=1,1" target="_blank">http://cgi.ebay.com/ebaymotors/ws/e...92140751&amp;rd=1,1</a>
