Engine Tighten belt... 2002
Discussion in 'Powertrain' started by CraigW, Sep 17, 2004.
    CraigW New Member
    The tensioner will keep the belt tension constant throughout the belts life of 50-60k miles. CW
    speedynole New Member
    Tallahassee, Miami, Fl
    How do u tighten the belt on a 2002 corolla
    how bout if i wanna change belt?
    CraigW New Member
    With the right tool the belt can be changed in a matter of a few minutes if not seconds.
    I suggest an OEM but Gates brands are good also.
    Get the belt from the dealer and check their install time and just get a trusted local mechanic or TRUSTED lube shop to install it.
    Check their rate to install, let them know you have your own belt and it should be simple and low cost. (it was for me)
    CW
