Engine Ticking noises around engine area when idle
Discussion in 'Powertrain' started by Gold00, Aug 18, 2005.
    Gold00 New Member
    Hey guys,
    I have a 2000 Corolla VE and for the past two days the engine/alternator area of my car has been making ticking noise when I am at a stop or in parked (auto trans).
    My car has always been pretty rough during idle, mainly because I think the guy who sold it to me didn't do a very good job at restoring the whole front part of the car. It is salvaged. Everything under the hood is standard (no performance parts). The speedometer reads ~66k miles but it could very well be higher. When I first got the registration, DMV stated that the miles didn't match with the records. I'm not sure if the guy messed with the miles or what.
    When idle, the hood has been shaking but never has it made this ticking noise. I noticed this noise on Sunday after I had made a turn after a stop. At first it was actually pretty loud, but the ticking has died down since then.
    It's not too bad, but you can definitely hear it if you listen closely. As stated above, I have a pretty rough idle. But one thing I notice is that the car doesn't shake too much when I have the AC on. When I turn it off though, the rough idle starts again and the hook shakes.
    I went to get it checked out today and both mechanics that I went to didn't know where it was coming from. Both of them told me that they would probably need it for half a day in order to check further and locate the problem. One guy told me that it definitely doesn't sound normal and that I do have a rough idle.
    For a further inspection, I'll be charged $40. I won't be able to get my car in until maybe Thrusday so I wanted to get your opinions on this. Have you guys had this problem before? If so, what was the cause? I wonder if I let it be will it cause long-term damage. Nothing seems to be falling apart just yet. I just hope it isnt the timing chain about to snap.
    I've had the car for probably a year now. I've changed the spark plugs and the sepentine belt (both from Toyota). Should I get the inspection just for the sake of doing so? Maybe they will check the condition of my timing chain while they are in there. The mechanic told me that after he's located the problem in the inspection then we will go on from there.
    Anyway, any input is greatly appreacited. I'll stick around and learn. Thanks!
    Update: Just came back from the mechanic. Spent $80 getting an inspection and did not get it fixed yet. The mechanic recommends that I get my valves adjusted and check/replace the valve cover gasket in the engine. He told me that some of the valves are too loose while the others are too tight - causing the rough idle.
    They estimated the job at $242 dollars but I think I'm going to go elsewhere anyway. The inspection was supposed to be $40 if I got the valve cover gasket changed with it ($155 total), but since they told me they might need to adjust the valves (raising price up to $242) I decided to wait it out. Ended up having to pay the $80 for the full check out. After they did diagnostics and ran tests, everything seemed to read normal (idle and sensors).
    What do you guys think? The mechanic told me that this is a routine maintance for 60k miles.
    edit: Called another shop for a quote. They quoted me for $85 to replace the valve cover gasket and adjust valves. $242 vs $85! Talk about a difference! Labor fees suck.
    Oh yeah, the reason the gasket might need to be replaced is because during the inspection today they took out the spark plug wires and there was oil on the tip. They think it's leaking so I need to get them replaced. The valve adjustment might reduce the rough idling but I've yet to figured out where the ticking noise is coming from. I'll probably end up going to the people my dad knows on Thrusday and check out what their prices are. But there's definitely a huge price difference between the major chain and privately owned shop.
    Is $85 reasonable for a job like this or am i just getting ripped off?
    01rollas New Member
    Wait a minute a 2000 with vvt-i? right? well in that area there is a sensor located above the alternator. that is a oil feed sensor AKA on of the VVT-i system sensors. its rare when they go bad so you might want to do this. Get a 10mm socket and remove it may be a bit stuck on there since it was probably never removed since it was built. Just disconnect the harness first and then pull back slowly. get some throttlle cleaner and clean it out completely. after it dries soak the internal part (the part that had oil when you removed it) with oil and re-install.they get dirty from time to time. if its not that have your timing chain checked and have the tensioner checked as well usually with a small pry bar, this is to check to see if the internal spring is still good. More than likely it is.BTW when was the last time you changed your oil and at when are the intervals, also what kind of weight do you use or what type?Valve adjustment i highly doubt that may be needed but it depends on how you drive hard or not.Do this first and get back to us.
    DeebsTundra Big Tires :)
    Near VoRtEx
    ...wow, there's some top quality mechanical work.
    "Yup, that sure don't sound right."
    How long since you had an oil change?
    teevee247 Well-Known Member
    Montreal, QC
    Maybe get a tuneup, make sure everything is adjusted to spec, change your oil (with an additive to help clean any gunk on the valves, etc.),
    01rollas New Member
    thats the word i was looking for last night, tuneup!
    Montreal, QC
    Just to add, always check the easy, free, and cheap to fix items first... its always nice finding out it was something simple....
    hehe lifter rattle in a toyota... --- isn't that a noted feature? ;)
    01rollas New Member
    Montreal, QC
    Rattles must be a problem of the 98 and up Corolla's :D
    My 94, evenw ith over 300 000kms, didn't have any rattles, and only had 1 squake (over bumps there would be a little squeak somewhere behind the dash), extremely solid car, less rattles than my friends 2002 Cavalier, lmao
    01rollas New Member
    my 98 LE shaked a bit but never made any squeaks or rattles that other people would notice them but oh well. the 01 S. well since the engine was directly bolted to the frame it shaked only when cold then smoothed out and thats about it,
    Montreal, QC
    That could do it... heh
    Gold00 New Member
    i went to a personal mechanic and he said theirs nothing to be worried about. the previous mechanic that check the car cleaned off some oil and now it doesnt sound or shake that bad. thanks for all the help.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    could be the new seats fitted to the 1zz-fe... they aren't made the same I heard... 1zz is a laser made thingy.. which was smaller and blablablablablablablabla
