Ticking Noise
Discussion in 'General Discussion' started by rubenscorolla1998, Feb 1, 2010.
    rubenscorolla1998 New Member
    Ticking Noise
    Hey guys,my name is ruben and this is my 1st post on trdforums :)
    i have a 1998 corolla, and about a week ago it started making a ticking noise when accelerating. but only about the 2-3k rpm range. if i let go of the gas pedal, or accelerate pass 3k rpm it goes away. ive checked for anything lose in the engine bay, but nothing. its a 5-speed manual trans. it makes the noise in 1st, 2nd, and sometimes 3rd. ive never heard it in 4th. what do you guys think it is?
    thanks in advance.
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    Welcome to the forums. My car makes that noise too. noones been able to help me out. good luck
    erickscorolla1999 Member
    WELCOME to the forum. Any pics of the ride ???????
    but its definitely not a rod or anything inside of the engine?? right :sad:
    thats all im worried about. thanks for the quick reply!
    and pics of the ride soon to come.
    Pump up zeee BASSS
    No more ticking LOL.
    Works for me :D
    no bass for me. weight reduction :) LOL
    lol... my sub weighs maybe 5 lbs :D
    I've taken a dump that weighed more than that lol. Probably made just about as much noise too. :D
    SaberJ2X Lurk MOAR
    Mayawest, PR
    1... check oil level, fill it to max (or a lil bit over... not much though)
    2... use heavier oil...
    3... post a video
    did number one. next is 2 & 3. thanks
    Oshkosh WI
    DeebsTundra Big Tires :)
    Near VoRtEx
    CV Joint maybe?
    Oshkosh WI
    My car is an automatic. It only does it when you surge the accelerator. Or when you have crusie control set at at between 55-80mph. Its right around the tne 2500-3500RPM range. its in the engine of my car. Im assuming something in the head. Noone can figure it out.
    nyrican52884 Active Member
    Plymouth, MA
    I don't think its a clutch.
    bennyboi9 Well-Known Member
    Brisbane, Australia
    theres a bomb in it!
    darkgamer1912 Member
    CT USA
    i know what that is because my car is doing the same thing except i havent fixed it on mine yet. its the serpentine pull tensioner there was a tsb from Toyota to change it on our corollas. it will get worse as times goes on but its just the shock that keeps tension on the belt that is going. its like 150 at Toyota or get it from another place
    ^^It very well could be the belt tensioner. Other possibilities could be the valve seats and transmission.
    Oshkosh WI
    See someone told me it needed valve lash adjustment. i looked into that on aldatapro and it said with our cars having vvt-i its all self adjusting and none of that was serviceable. I did see the tsb on the serp belt tensioner going bad. back then i didnt have money to replace it but now maybe I should. Thanks for reminding me
    CT USA
    yah thats it but im kinda skeptical about using anything other than a toyota part on this one which is the reason i havent done it yet. they fixed the part so what says the aftermarket ones wont do the same thing
    Yea im going with OEM. $150 everywhere I've looked. How hard is it to change???
    If you're mechanically inclined, it's not hard. About the same difficulty as replacing a pulley. If it's your first time, you might have a hard time.
    Denver Rolla 98 impreza
    if you have a CAI or SRI I know exactly what the problem is.. ^_^ its your vacuum control unit resonating of of what ever surface you have it mounted to, there is no ay to stop it, just turn up the music..
    no, i have a stock intake. soon to be cold air :cool:
    CT USA
    so thats what the other sound in my engine bay is. ill have to look into that.
    I took it to someone and he said he thinks its a piston :(
    i did a little research using the search button :D
    found out it could well be serp belt, tensioner, valves, lifters and a couple of other things. im thinking of taking it to toyota to get it checked out to find out exactly whats wrong. and then from there determine if its worth it for me to fix it or a mechanic. btw does anyonne know roughly how much toyota charges per hour. thanks
    update: engine died :sad: is it possible to close the thread.
    Update: How did it die?
