Engine throttlebody coolant bypass
Discussion in 'Powertrain' started by trdracing2005, Mar 7, 2006.
    trdracing2005 New Member
    Portsmouth, virginia
    Can someone give me a more detailed picture of what hoses to dissconnect and connect for this mod??? I am doing it because im workin on the throttle body right now thanks, Justin
    rolla02 Corollalcholic
    Delaware
    thats the problem Which tube is it... :superconf :superconf :superconf
    both as in? come on guys any pictures???
    tunerperformance New Member
    florida
    you know i almost did this diy today but then i got to thinking if you actaully look at where these lines go its part of you emmisions why would you want to do this no gain for this mod whats so ever those lines go into a sensor i cant remeber what its called one of my techs at work told me today not to do this mod no point and plus its there for a reason
    Throttle body coolant bypass mod is one of those ideas that actually had some performance bearing in some cars - but completely got twisted around and misunderstood over the years. Actually used in F-bodies and Mustangs with great success - but those systems are vastly different than what you see in our Toyotas.
    On a highly optimized FI engine - I wouldn't do this mod. In almost all cases, you'll experienece almost zero gains and in some situations, lose of power.
    The basic idea is to keep hot coolant away from the TB to maximize performance (colder air is better idea) and that this "cold start" feature is not needed in warmer areas - sounds good in passing, but realize that the throttle body runs much hotter than coolant temperatures in normal operations (with coolant being very good moderator of temperature variations (almost a constant heat bath) - higher temperature of motor dictated by emissions regs). Also heating the TB evenly will ensure that the flow of air though it is maximized through the TB (boundary layer right next to TB walls will help "insulate" the air temps moving through the TB and help keep the air moving easily).
    polo708 New Member
    9thgencorolla.com
    ^^ highly agree. You arent going to see much of a gain, actually you probably wont see any gain at all except for the one in your mind haha. Also, if you live up north and you do this mod... you could be hurting come winter time. IMO... leave it be
    sonsofwisdom I can fix it
    Austin area
    another ricer mod...same as egr valve disconnecting and taking off the vacuum line on your fuel press. regulator
    *shakes head* oh well
