Engine throttle cable tension?
Discussion in 'Powertrain' started by toyotaspeed90, Sep 1, 2004.
    toyotaspeed90 New Member
    Bellingham, WA
    it being that new, it might be electronically controlled.....dunno, never worked on an 03 civic
    kaosfm Guest
    jrolla Guest
    my friend has a 03 civic, maby somebody knows? is there a way to tighten the tension in order to get a more agressive throttle response. pulleys maybe? if anybody can tell me anything, i'd appreciate it.
    d_samurai Guest
    usually there's the matter of tightening the throttle cable right next to the throttle body...which involves unboltening and pulling so there's no slack in the line- some say this is good, some say its bad b/c it could mess up your idle i believe..
