Engine throttle cable readjustment...
Discussion in 'Powertrain' started by CorollaULEV, Dec 8, 2004.
    CorollaULEV Guest
    LOL. Yeah...it wasn't one of those "well, I'll leave it for now and fix it later" sort of deals. I about burnt my hand trying to get it, too - got a little hot with 300 or so amps flowing through it.
    Trav
    CorollaULEV Guest
    So there's quite a bit of slack in the throttle cable. The throttle plate doesn't even start to open until the gas pedal is about 3/4" down. I've read somewhere about people tightening up the throttle cable so that the gas pedal is a little more "responsive". But others were also worried about too much force being applied to the throttle with that extra 3/4" of travel to the floor board.
    Fix for that:
    Pull the carpet back and stuff a folded rag or small towel under the carpet. Replace carpet...problem solved.
    I also re-did my engine grounding and just about welded my 10mm wrench to the negative battery post. Lots of pretty fireworks. Fun stuff!
    Trav
    recklessfour Guest
    good tip. about the wrench? did u get it out?
    d_samurai Guest
    maybe someone can help me here- my pedal makes a slight squeaky noise when pressed down hard- can i just WD40 it? or will that cause problems.. thanks..
    CorollaULEV Guest
    Yep. WD-40 on the throttle spring. I think lithium grease is probably a better choice for the cable itself - it sticks a little better. You can get it in a spray can also. There's also a spring on the gas pedal itself. Check that, too.
    Trav
