This seems interesting.
Discussion in 'General Discussion' started by Altis 1, Apr 29, 2004.
    Altis 1 Guest
    I got really bored today so I did some calculation to pass the time. I wanted to see the power to weight ratio of several cars, especially the 2005 Scion TC. Here is what I got.
    1. Honda Civic EX Coupe
    1.7L vtec
    75mm bore x 94.4mm stroke
    127 HP 114 lb.-ft.
    2597 LBS
    Power to weight ratio of 20.5 lbs to 1 hp
    2. Honda Civic Si
    2.0L vtec
    86mm bore x 86mm stroke
    160 HP 132 lb.-ft.
    2782 LBS
    Power to weight ratio of 17.3 lbs to 1 hp
    3. Toyota Celica GT
    1.8l vvt-i
    79mm bore x 91.5mm stroke
    140 HP 125 lb.-ft.
    2425 LBS
    4. Toyota Celica GTS
    1.8l vvtl-i
    82mm bore x 85.4mm stroke
    180 HP 130 lb.-ft.
    2500 LBS
    Power to weight ratio of 13.9 lbs to 1 hp
    5. Scion TC
    2.4l vvt-i
    88.5mm bore x 96mm stroke
    160 HP 163 lb.-ft.
    2905 LBS
    Power to weight ratio of 18.2 lbs to 1 hp
    The Scion TC has to pull more weight than the all of the cars (except the Civic EX) but it has the most torque at 163 lb.-ft.
    CorollaAltis New Member
    Toyota Corolla S
    1.8L VVT-i
    130HP 125 ft-lbs
    2524 lbs
    Power to weight ratio - 1hp to 19.42lbs
    DBurcombe Guest
    Re: This seems interesting.
    The power to weight ratio is 17.4 lbs to 1 hp
    good info though
    If you average weight per torque and weight per horsepower you get this:
    Toyota Celica GT-S....16.6
    Scion tC......................18.0
    Toyota Celica GT........18.4
    Toyota Corolla XRS.....18.4
    Honda Civic Si............19.2
    Toyota Matrix XRS.....19.3
    Toyota Corolla S........20.0
    Toyota Matrix XR.......21.2
    Honda Civic EX..........21.7
    Scion xA...................22.0
    Scion xB...................22.5
    SERG4U Guest
    can someone do it with a corolla+s/c
    bzzsan Guest
    if you add 20 lbs for the s/c, weight = about 2545
    with hp ratings at 166 and torque at 145
    15.3lbs per hp and17.6lbs per torque
    and the average of the lbs per torque and hp =16.4....... which puts it at the top of that list up above....kick ass
