Engine Tensioner Replacement
Discussion in 'Powertrain' started by Ro2la, Aug 8, 2005.
    Ro2la New Member
    Los Angeles, CA
    I recently took my 02 corolla to get an oil change from toyota. They noted that my tensioner was leaking grease and needed to be replaced. I was wondering how difficult this would be as a diy. I found a really great diy for a VW vr6 which makes me think i can pull it off. Any info/ pics pointing me in the right direction are appreciated.
    Thanks
    Barnacules 100101101011011
    Duvall, WA
    What is a tensioner? :)
    asn13oy Stepping Stones
    OC, CA
    I think he's talking about the tensioner pulley for the engine belt.
    Ro2la New Member
    Los Angeles, CA
    OC, CA
    Bustin' out the Haynes manual...
    1. Remove the drivebelt.
    -Rotate the belt tensioner clockwise to release the tension (to release the tension on the drivebelt, place a long wrench or socket and ratchet on the hex-shaped boss[the bolt, not the nut], then turn clockwise), then slip the belt off the pulleys. Slowly release the tensioner.
    2. Remove/Install tensioner
    -Unscrew the mounting bolt and nut
    -Installation is the reverse of the removal procedure. Tighten the fasteners to the torque values (nut = 21 ft/lbs)(bolt = 51 ft/lbs)
    3. Re-install drivebelt
    -Route belt over the pulleys, again rotating the tensioner to allow the belt to be installed, then release the belt tensioner.
    Don't forget how the belt is routed around all the pulleys
    Here's the order (following clockwise, as if you were looking straight at the side of the engine:(
    1. alternator (follows to the right)
    2. water pump (follows to the left)
    3. AC compressor (right and then under)
    4. crankshaft pulley (left and back up)
    5. tensioner pulley (right all the way around)
    6. power steering pump (left and then over)....and then back to the alternator
    Ro2la New Member
    Los Angeles, CA
    good stuff, thanks man i appreciate it
    Legit01Rolla Active Member
    SHit i just changed my tensioner and belt too....cuz my tensioner was leaking like hell and my belt is fucked up....it cost me 400 G mayn...fucking tensioner hella expensive as fuck...
    tensioner leaking? *huh?*
    ok, perhaps its diff on the 98/99 motors... there's nothing to LEAK on the tensioner... lol (i got like 3 of em)
    01rollas New Member
    they have and internal bearing system that cracks over time and leaks the grease.
    ahh... ooookay.
    SERPENTINE TENSIONER, Corolla 98-03 $113.30
    Not too shabby. glad I got a couple around tho, lol...
    01rollas New Member
    i have an extra one thats it. form my 98. the only thing that is different from the 01 S is the design of the spring/mini strust linkage.
