Engine Tensioner Assembly Leaking
Discussion in 'Powertrain' started by jdmikey, Feb 16, 2008.
    jdmikey New Member
    I just noticed that my tensioner is leaking oil from the shock that is built onto it. It also makes a rattling noise. Does anyone know if the tensioner is suppose to vibrate? When I put the car in gear and look at it, it will be vibrating. Maybe this is what is casusing my car to vibrate while driving?
    plu Well-Known Member
    SC
    It's a $49 part from Advance Auto Parts compared to over $150 at the dealership. Only took me an hour to replace mine with hand tools. I would change it out to be safe.
    Legit01Rolla Active Member
    ya change it man its so easy
    jdmikey New Member
    i can see that it's easy to install. im just wondering if it leaking and all could be causing my mysterious vibration?
    ShallowPockets New Member
    Memphis
    Possibly. I had a spring-loaded one on the old car. Right before it went I had a fair amount of vibration that I initially attributed to a worn motor mount. It was the tensioner.
