Engine Tach install
Discussion in 'Powertrain' started by E91atmosk, Apr 14, 2006.
    E91atmosk Guest
    Tach install
    I dont know which genious at Toyota decided to offer a manuel trans car without a tach, but I go tstuck with one. Does anyone knwo how to install an aftermarket tach into the car? I havent taken apart the dash to look but I doubt there will be an extra useful wire back there and I dotn really want to wire it straight into the ecu. my car also seems to be missing the plug under the hood where you can plug in a tach to run diagnostics with.
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    what year and trim?
    if its 7th gen and u have a DX i believe you can buy the stock cluster with a tach and its plug and play...after market tachs are to tacky and big for my style
    E91atmosk Guest
    I have an 8th gen and the tach I have to install is only 2.5 in in diameter, I want it for reference, not to look cool.
    what. trim. level?
    E91atmosk Guest
    oh, um, CE, with no options
    SleepinRolla Member
    Socal
    you can buy an 8th gen tach cluster on for fifty bucks or less and just swap your speedo so that you milage will right will look much cleaner than an afteramrket tach.
    ^^^ agreed.
    monkey4005 New Member
    i swapped mine for 20 bucks off of ebay.. looks way better
    redborja202 Guest
    i swapped mine too 30 bucks off of ebay... and i also got indiglo guages on it... it looks badass... i also changed the bulbs to amber... so the pins light up amber at night with blue/green background... lol...
    yeah, ur better off swapping ur cluster...
    E91atmosk Guest
    Cool, I think I have a junkyard run in the near future ^_^, thanks a lot guys
    If you want to use aftermarket tach, the signal wire is black, just try it one by on and you should be able to find it real quick.
    hey...if you go to Crazy Ray's, do me a favor and look for an 01 corolla front sway bar? i haven't had the chance to get down there yet...
    E91atmosk Guest
    will do. kinda creepy though cause that was exactly where I was planning on going... *shifty eyes*
    that's the closest to you...i used deductive logic. i'm only a half hour from you in no traffic, dude...i know the area pretty well. ;)
    redborja202 Guest
    man, the junk yards here in chicago doesent have any 8th gens... the newest they got are just early 7th gens...
    nocpan New Member
    look for old induction tach... install is easy ... you wrap the tach wire around shortest sparkplug wire and you are set :) and it will be much cheaper too....
    but if you can;t swap out the cluster do get a tach.
    on the 8th gens to swap it out all you have to do is pull the plugs out of the old ones and plug it in to the new one. if you do this to one with an outside temp on it you wont have the sencor so it wont work and it will say error. then you might have to get the sencor. i got mine off an old car that no one uses because the dealer wanted $63.00 U.S.
    krazykanuk New Member
    2000 corolla VE tach install
    from my old 1999 tercel which was also a manual i ripped out my tach after being t-boned and writing off the car. i now drive a 4 door 2000 corolla ve. since i already have the tach, and the can and am very short on cash as legal fees to fight the ticket and insurance, where could i find the tach signal wire. i know many of you don't like aftermarket tachs.. but i like mine adn how it will loof in the car.
    if anyone would know where that tach signal wire is it'd be greatly appreciated if you could let me know.
    Thanks
    I forgot with wire it is. But the signal wire is Black in my 01. You just need to try them one by one (I think there is only like 4-6?) and you should be able to find it. :)
    E91atmosk Guest
    I installed the tach today and the signal wire is definately black. There were a couple of black wires, maybe one per clip of wires ( 4 clips total ), but if you look closely at the back of the gauge cluster itself, you can see that one of teh black wires doesnt connect to anything other then a blank connection. Thats the tach signal wire.
    Got this pic from other forum.
    The signal wire is in that clip
    i saw that pic aswell
    thanks for the help guys
    going to install it today if i get the energy
