Engine Tach install Help?
Discussion in 'Powertrain' started by MovieSTAR, Sep 8, 2007.
    what i did was i just replaced my dash cluster with an LE cluster.
    it has a tach and its a direct fit and it looks spiffy
    Exactly as he said. Simply replace the old cluster with a cluster that has a tach. Everything is plug and play.
    Stupidumbface Guest
    Tach install Help?
    I have been sifting through posts and links on SEVERAL different Toyota forums, and no one seems to have ever actually answered this. Where can I get a tach signal on a 2001 Corolla?!?!?!? I have read that you can get it from the diagnostic port, but I tried getting signal and nothing works. I know there is a source behind the dash, but no one has EVER specifically said where it is. Please respond ASAP...
    eddy Well-Known Member
    I thinks rainbow_star here (if I'm not wrong) has an aftermarket tach installed. PM him.
