Engine Synchros or clutch?
Discussion in 'Powertrain' started by blancokracker, May 15, 2004.
    blancokracker Guest
    Synchros or clutch?
    Well this only happens going into 2nd gear, soo....
    When I'm either driving hard or im doownshifting, sometimes when I go into 2nd it sorta hits, revs up 2 grand (without any moving force), then catches. I know the clutch is pressed in all the way. It sounds bad lol. So do yall think its synchros (I don't because I rev match so the synchros shouldn't be that bad for it, I do because its only in second gear) or the clutch ( I do because of the neutral like rev up before catching, I don't because it only happens in 2nd).
    BTW two people have learned manual on the car and it has 35 k miles (2001).
    thanks
    corolla_racer Guest
    i say clutch to man.... i have a act stag 2 clutch....I love it man....hehehe....Man i tell u it take me n my freinds 3 n a half day to do my clutch at my house.....holy cow it was hard....I'm telling u if u do yourself have man....hehhe
    polo708 New Member
    9thgencorolla.com
    I'll 3rd the clutch, haha
    I'd lean more towards the clutch... sounds like its not engaging... usually when synchros are going out you get a grind no matter if the clutch is in all the way or not... *shrug* then again its hard to tell unless I drove it.
    TurboRolla21 Guest
    Clutch...Not synchros...You need to get a Spec stage 1 clutch. I can get you one!!!
    Started to sound like the synchros b/c most all cars (especially Toyota and Mitsubishi) have trouble with the synchros in 2nd gear but no grinding means they are safe.
    You come out on the good end. Synchro's=Tranny work=$$$
    Clutch is cheaper!
    blancokracker Guest
    still like 500 installed >_>
    TurboRolla21 Guest
    still cheaper though....Tranny work sucks b/c they have to pull the whole tranny out (that's where all the money's at)
    hehe wayyyy cheaper to do the clutch than actual trans work...
    TurboRolla21 Guest
    I can get me a Spec clutch and flywheel (installed) for $400...That's b/c I am good. I got the hook up. hehe
    blancokracker Guest
    Ima problay buy one around september, with a fidanza flywheel and see if i can convince my parents to take the labor charges as my 20th birthday present lol.
    Mike4831 C-Town Pimp
    Statesboro, GA
    Yes it would def be the clutch. If a syncro was going you wouldnt have the power that your engine normally has. Also if u let of the clutch to fast the car will jerk and will hesitate getting into gear. But be thankful it is the clutch.
    RollaS New Member
    Are they quality parts?
    My TRD Japan clutch, clutch cover, and lightweight flywheel, came out to $800 for just parts. This is getting them at wholesale prices too.
    TurboRolla21 Guest
    Yeah...Big company in Birmingham called Spec Performance. I can get parts for discount and labor almost free--because I am special! hehe
    corolla_racer Guest
    Will the clutch cost me only 300 even because my friends works at this racing place....
    corolla_racer Guest
    One more thing i will being gotting a lightwight flywheel in 3 weeks...hehe
    CadetLee Guest
    I paid over over 600 for the clutch/flywheel combo...and another 360 for installation..it was worth it, though.
    TurboRolla21 Guest
    Holy crap! I am so glad that I got hook ups! :D
