Switch Panel
Discussion in 'Interior' started by maancalo, Oct 7, 2003.
    maancalo Guest
    Switch Panel
    He y, i have a 2004 ce and im thinking abt installing the power window kit but i dont want those cheap switches the kits com with. does anybody know where i can get an OEM switch panel?
    moonshadow ||\\|||D)||\\||
    Jersey City, NJ
    the OEM switch panel may not work, its way to complicated. if i am not mistaken, the last time we went over this topic, each switch had 13 wires running into it from thr switch plate.
    maancalo Guest
    Well, i guess im gonna have to use the cheap ones. thanx anyway
    stinky Guest
    show us some pics of the install when you do it.
    maancalo Guest
    Sure, i´ll post them as soon as i get it done
    xtm "Member"
    Panorama City, CA
    Good luck finding the OEM switches-- since the 03 Corolla is so new, it's very hard to find OEM parts on eBay and local junkyards. If you go to a Toy dealer and order parts, they will most likely cost you a couple hundred. My suggestion is to use an older 98-2001-ish Toyota OEM window switch and fabricate a plate for it somewhere on the door panel.
    LMK if you need wiring codes, I have them.
