Sway Bars
Discussion in 'Stop, Drop & Roll' started by gtrwndr, Aug 23, 2004.
    gtrwndr Guest
    Sway Bars
    Anyone have the Progress 22 mm Rear Lower Sway? How do you like it, I'm a little worried that 22 mm is too stiff. Do they make a matching front lower? I already have a front upper sway and am running 205/60/R15 V.
    DIABOLIC HIPPO Guest
    No, its not to stiff at all..
    Its a great bang for the buck part though.
    You'll feel the difference on the turns.
    Its a great upgrade, I had it for a while, then I went with the hotchikis f/r swaybars.
    Though hotchkis had problems with the rear swaybar welds cracking.
    rolla_dink Guest
    just installed my progress bar over the weekend. The rear end feels different in a good way. It is much tighter and the rear end ride more evenly. It was hard for me to believe when I was swapping out the stock and progress bar, but I can take turns and the under steer is minimized. the rear end does seem to bounce more with the Koni Yellows though. Overall, I like it so far.
