Sway Bar Bracket Bolt Size?
Discussion in '8th Gen' started by Suav0, May 30, 2014.
    Suav0 New Member
    Hey guys. I just bought a oem front sway bar at a junkyard forgot to take the bolts for the brackets as well. Can anyone tell me the bolt size so that i can buy new ones? thanks
    You can call the dealer and ask but off hand i dont know. i can check later on
    Where are you located? I could grab them for you.
    I wonder if they are the same bolt size as mine, I had to replace them all after over torquing
