Engine swap MR2 engine
Discussion in 'Powertrain' started by RoLLa4sHo, Jul 23, 2004.
    RoLLa4sHo Guest
    swap MR2 engine
    is it possible to swap an MR2T engine into a 2000 Corolla? if so, what year MR2 is best to swap in? 2nd or 3rd gen?
    02RSX Guest
    yes it's possible. 3rd gen didn't have a turbo, so 2nd gen obviously. I'd probably go with the last year if u can find one.
    it's a ton of work, kinda pointless, but it is possible.
    RoLLa4sHo Guest
    what is the last year of the 2nd gen motor? or should i just turbo a 3rd gen?
    BLADDER_MASTER Active Member
    FL
    2nd gen MR2's | 1991-1995 | Came Non-Turbo (5S-FE) and Turbo (3S-GTE)
    3rd gen MR2's | 2000-Now | Came only Non-Turbo (1ZZ-FE)
    If you want to drop in a 3S-GTE engine, which came in the 2nd gen MR2's, then you're going to need money for it. It involves a lot of work and look for the project to be close to costing $10,000.
    If you want to drop in the 1ZZ-FE, you're better off just turbocharging the current engine you have.
    Both engine swaps are possible. You just need the time and money in order to do it.
    02RSX Guest
    not to mention u already have a 1zz in your corolla.
