Engine super charge 03 camry 2.4l engine
Discussion in 'Powertrain' started by migoreng, May 6, 2004.
    migoreng Guest
    has it been done before?
    how much for it and labour too...
    i live in australia
    or what about turbo?
    97ae102 New Member
    This is predominantly a Corolla forum, but there should be more information on Toyota Nation. More Camry owners there for sure, you might get more help there.
    blancokracker Guest
    ...The Tc coming out uses the 2.4 L 4 cylinder in the camry. TRD is making a centrifugal s/c for it, so it should also work for a camry. Will boost it only 40 hp, and we don't know when max psi is engaged at. Just go for turbo I'd say If you want the most bang for your money.
    02RSX Guest
    i believe ripp modds makes a supercharger for teh 2AZ-FE also, specifically for teh camry. not sure on price though. check out forum.toyotanation.com for more info, tehy'll be a lot more helpful since we're a corolla forum, not a camry forum
    Tokez420 Guest
    go to www.teamsc3.com they have a supercharger for the camry but i think its for the older ones.
    03silverrolla Guest
    why dont they make a 2.4 for the corolla..... that would be nice
