Engine Suggestions for performance mods
Discussion in 'Powertrain' started by rollarace, Aug 26, 2004.
    rollarace New Member
    Blue Bell, PA
    I don't think they're out yet for his year...I think ELP is coming out with one soon though...
    gimmemorepower Guest
    Which engine did you 2k rolla come with?
    Which engine does your rolla come with (here in South Africa in 2000 it came with the engine I have just bought - a VVTi 20v Blacktop 4AGE) ?
    stock, it produces about 160 HP at the fly.
    how much HP did yours produce stock, and how much now?
    Gimme
    2krolla New Member
    Birmingham, Alabama
    I own a 2000 Corolla and am in the process of figuring out what all I can do to increase the overall engine performance.
    So far this is the list I have come up with...
    Pulleys
    CAI
    Exhaust 2.25", Highflow Cat, Performance Muff
    Ground kit
    Voltage Stabilizer
    Denso or NGK Iridium Plugs
    Any other suggestions?
    Or is this where I should begin prepping it for Turbo or a Supercharger?
    RacingSolution New Member
    Wont need a CAI for a turbo... 2.25 will be too small with the turbo...
    BLADDER_MASTER Active Member
    FL
    -Cams (If they make aftermarket ones for your engine)
    -Higher compression pistons or lower if you're going to boost
    -Weight reduction
    2krolla New Member
    Birmingham, Alabama
    Well I did 2.25" (& CAI soon to be ordered) because I had not considered boost yet. Possibly down the road, but I was wondering what else I can do now.
    slvrrolla03 New Member
    Virginia
    upgrade header would be a good upgrade in hp
