Stock 2004 head unit.... can take AUX adapter ?
Discussion in 'Interior' started by ronin02, Feb 1, 2004.
    ronin02 Guest
    Does the 2004 stock head unit take those PIE aux adapters ? I didn't notice any "aux" or "tape" button on the unit... Also, is it difficult to install... can you lead it to the glove box or below the unit ? I'd like to hookup my minidisc player to the stereo.... was using the tape deck adapter, but that's not an option now..
    darrenwang Guest
    No, it doesn't. There is no audio-input solution for now.
    baller Guest
    YES THERE IS .. check my response to someone else's post .. i'll find it if i have time. theres a thing u cna plug into where the cd changer goes adn gives u a AUX input
    baller Guest
    topic 4522
    heres the link . read my post :)
    hey darren where in Taiwan are you from? Taipei?
    WebMasta33 Guest
    Well yeah, but the stock head unit itself doesn't have the ability to have inputs as the question was asked.
    Your solution would add a secondary device that would allow inputs. There is a difference :p
    But, you'd be better off just getting a cheap FM modulator if you wanna go cheap. Otherwise just buy a new head unit.
    ronin02 Guest
    I read the post... sounds promising, but how do you access the aux device ? as far as I can tell, the Corolla stock unit has 3 buttons "CD" "AM" and "FM | 2" ... Do you just press CD ?? And can you still use the stock CD player after this install...
    From PIE website..
    It is compatible with all 1998 - 2004 Toyota vehicles EXCEPT the 2003-2004 Matrix and Prius and factory radios with a face code of AD6806 and AD680
    http://store.yahoo.com/logjam/pietoyaux.html
    -anyone know their radio's face code ?
    PIE website says this for instructions...
    "VERIFY OPERATION:
    1. With radio on, activate auxiliary device.
    2. Press "CD" or "AUX" button on radio to gain access to auxiliary audio input.
    3. Display on radio will show CD 1 TRACK 1, and the audio of the auxiliary device will be heard.
    4. Adjust volume levels of auxiliary device. (If applicable)"
    http://www.pie.net/toy_aux_inst.htm[/quote]
    OK.. found some dude that has done it on his 04 Corolla... but no install guide !
    http://www.jthurber.com/blog/index.php?s=corolla&submit=search
    aarhelger Guest
    CD Changer controls
    From the PIE website it also says:
    "Your vehicle must be equipped with a radio that has CD changer controls."
    Does that mean it came with a CD Changer from the factory or do they all have CD changer controls?
    Andy Arhelger
    baller Guest
    it works . u hit the cd button. i have it in my car :) heh
    ronin02 Guest
    Do you have to make holes in the dash to run the RCA cables thru ??
    baller Guest
    nah my RCA cables are under the dash, under the steering column. If you stick your head under you can see it. I have my PDA hooked up t it with GPS
