Steering wheel.
Discussion in 'Exterior' started by Tonyota, May 18, 2008.
    Tonyota VVTI BLOWN..??
    Steering wheel.
    Just thinking here. However if I decide to change out my wheel. Has anyone done this ? Thought for sure Vamp would of, but didnt see anything. Just curious what I would be getting into. Also I need to find out if its legal to remove the airbag. I keep hearing different things as its legal and then no it wont pass safety ?
    yes
    legality varies from state to state. Also your insurance company may choose to drop your covage.
    Is it pretty straight forward ? What if any thing I need to be aware of ?
    you just need a star screwdriver bit to remove the airbag and a ratchet to remove the center bolt for the steering wheel itself. Then just pull the wheel straight out.
    brownsville, tx
    you should just upgrade to a nicer wheel with airbag from like a celica or just thought of this right now, 10th gen rolla. hmm wonder if that will worrk?
    tsburt Active Member
    miami
    i think if ur using ur car everytime, it would be a bad idea to have a steering wheel without airbag. ur gonna have to be carefull. just my two cents....
    JordanInc ZZE110
    i prefer steering wheels w/ airbags lol
    Airbags yea agree..But I like the D wheel. Also car is not used only on weekends now days. Being built for looks and should be able to surprise a few peps. OK sounds dam straight forward. Thanks all.
    Ares Active Member
    Houston TX
    I do it everyday.... :shutup::shutup::shutup:
    he did...he bought the Celica/Corolla S wheel.
    JordanInc ZZE110
    if i am correct, old cars dont have airbags on their steering wheels, so i believe its legal to have no airbag steering wheels in all states
    i dunno if its legal everywhere to go from a car with airbag to having no airbag..
    it's likely as legal as it is to put an older motor in a newer car (in other words, it likely isn't).
    You are correct at least here... However I can have the new wheel just wont pass inspection. So Ill install once a year.
    Ares Active Member
    Houston TX
    There is an alternative to that too... :ninjastea
    Yea know someone......
    corolla New Member
    I have the 9th gen steering wheel on my 7th gen corolla. No airbags though.
    brownsville, tx
    new guy with 7th gen!! i think cars prior to some certain year can go without airbags or something like that.
    it all depends on if your car came factory equipped with airbags or not.
    Thats what the law is here.
    JordanInc ZZE110
    wow so expensive
    as nice as it is, im still not convinced to buy one for that price and knowing theres no airbag
    DOT. Noypi ako!
    Those HAVE airbags.;)
    JordanInc ZZE110
    oh shitt lmao
    yep, pnp for all toyota/lexus/scions
    yakuza13 New Member
    I would be scared to remove a steering wheel(without proper step by step instructions) with airbag for the fear that it will activate and deploy! Ouch! :D
    Unplug the battery and wait a good half an hour or longer if you're paranoid. LOL :D
    My hell... Dont turn the key on. The airbags have no power until the key is switched on. Look at your diagram.
    there's still a current going through the car, however, and it's recommended to disconnect the battery.
