Engine Stafford Fabrications rolla 98-02 turbo manifold?
Discussion in 'Powertrain' started by GSE21tuner, May 30, 2004.
    I wanna build a custom turbo setup, but don't wanna buy Stafford Fabs full kit. I just wanna buy the turbo manifold and get my own turbo and accessories. Does any one know how and how much I can get it for? Please help, I hope to have this finished by summer. :D
    RollaRyder1103 New Member
    Corona, CA
    or u can buy it from monkey wrench racing
    sean2sean Member
    so cal
    its about 400-500 bucks... dependin wut u want... equal length... stainless steel... etc...
    blancokracker Guest
    doesn't it only fit a t3 though? Just in case you were thinking of getting a different turbo. If I ever go turbo Id want a Garret GT25R but the turbo alone is like 1300 0_0
    blancokracker Guest
    Also if your gonna make the kit in say 3-5 months might as well order it now. It probaly won't even be ready by then LOL.
    corolla_man_j Guest
    im going to be running a t25....
    Lekz Guest
    i dont think a rolla needs a turbo like that....a t3 is good enough
    Pantaloon007 Guest
    t3 would make you be very very happy...
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    The one on monkeywrench is for the Celica only.
    blancokracker Guest
    why not the gt25r is made for 1.7-2.5 L. The hp range is like 180-350. Lower psi with more power and very quick spool up.
    all u have to do is ask them to weld on a dip shit t25 flange instead of a t3 flange.. it's custom made after all.. and yes the gt25 BB turbo is an excellent choice for 1.8L corollas, dont believe me look at a compressor map, its more ideal than a t3 unless you are going for big power (with internal upgrades + fuel management)..
    Heres a tip on getting a nice GT25: mazdaspeed protege.. Internal wastegate is already set at 6.8PSI.
    And if stafford won't sell you the manafold, buy from spool, go with JGS tools if u are despirate..
    I already have the stock turbo off of the 1st generation Mitsubishi Eclipse GSX. What kind of flange will I need for that?
    superpilun Guest
    look at the compressor housing, if it says TD04 or TD05 than it uses the standard 14b flange (it's rectangle)
