Speedo - Odo Caliberation
Discussion in 'Interior' started by eddy, Aug 2, 2007.
    eddy Well-Known Member
    I just won the auction for a guage cluster with tach that was posted in the FS forum here. I did not realize that it was a kmph speedo and not an mph. Where is the caliberation info stored for the speedos in our rollas? Is it the ECU or is it in the speedo itself? If its in the ECU, I'm worried that even if I do swap the speedo, it wont work properly. If its in the speedo itself, then it might just work, but theres another issue, the cluster was pulled out of a 98 rolla in Canada. Mine is an 01, and it has that interior ambience sensor something something, and I'm not sure if all of this is gonna work out smooth, or will I end up in trouble for messing with the cluster.
    jcrwzr Member
    Simi Valley, CA
    just have someone with a radar gun to check your speed. use those ones that the baseball players use. then convert the kph to mph. i mean you have a tach now. the kph gauge is useless now. just go by the speed of your tachometer. but have someone radar/lidar your speed.
    or you can buy an obd2 software that plugs right into your computer.
    other than that, i don't know anything about calibration as to where it is or how it fixed. i do know that some cars or trucks recalibrate their speed because they have aftermarket plus sized wheels which throws off the odometer and the speedometer. goooood luck.
    or return it.
    Maybe you can convert the kilometers to miles and draw new lines on the speedometer.
    jcrwzr Member
    Simi Valley, CA
    after you determine the speed with the radar scanner
    daniel2002p Guest
    dont canadian models have kmh on the outside in big numbers and mph on the inside smaller numbers on the speedo and then the needle is correct no???.... bc I think the needle always moves the same its just the number pad that they had to remake... could be just me tho
    D
    jcrwzr Member
    Simi Valley, CA
    but the marks may be different between corolla generations
    daniel2002p Guest
    ^^ oh yea didnt think of that
    D
    shubert_ae102 New Member
    de mountains :D
    62 mph = 100klm
