Sound Destroyer
Discussion in 'Interior' started by kudkud, Feb 28, 2007.
    kudkud Member
    Port Charlotte, FL
    Tulsa, Ok
    Did a few minutes of researching for ya.
    -When tested against Dynamat in the same type of vehicle with the same equipped system, Sound Destroy was equally matched with Dynamat in terms of performance with only 0.1 dB difference between the two (Dynamat was higher). (NOTE: this test was conducted by Sound Destroyer....)
    -Feedback from other ebay customers have for the most part, yielded satisfactory results.
    -it is made from a butyl layer with an aluminum surface. It also uses a sort of polyethalene or Mylar constraining layer instead of the 4mil aluminum layers used in Dynamat Xtreme (whatever that means)
    -The 50mil version of Sound Destroyer is half the weight of Dynamat Xtreme. Probably could expect half the performance...
    This is just what I found so you didnt have to. I still suggest you research it further just in case the information I gave you was correct and unbiased.
    Des Plaines, IL
    Have you considered a spray on deadner? From what I hear Second Skin makes good stuff and thats what I plan on using on my car.
    kudkud Member
    Port Charlotte, FL
    Thanks for the research. I'll do some more. :)
    When do you plan to install the spray on deadener? Let me know how it goes.
    Des Plaines, IL
    Not for a long ass time lol. Im broke and want other things first.
    has anyone used dynamat on their car?
    i'm about to purchase the door, trunk and put some by the rear speakers...
    they're pretty much all the same.. just foil with a tar backing that weighs a ton.
