Engine Smog question
Discussion in 'Powertrain' started by imported_rolla97, Jun 24, 2004.
    imported_rolla97 Guest
    Smog question
    I had my 97 smogged but didnt pass. The guy said i'm running too lean. I have headers with that sensor that screws in at the bottom, stock catalytic con. and stock muffler. The intake i have doesnt have that hole where the sensor plugs in. The sensor is just hanging there not plugged in. If I put the stock intake back on will I pass smog?
    Mike4831 C-Town Pimp
    Statesboro, GA
    umm where do u live first off. check your o2 sensors.
    if the IAT sensor isn't plug in i would think you would be running more rich than lea.. I would suggest you put the airbox back in along with checking the conditions of your sensors
    triune530 Guest
    Try plugging that IAT sensor in your intake. What's your location?
    d_samurai Guest
    if its dangling loose-it all depends on the temps its reading-if its hotter than the air comin in your intake-that would cause the "leaniness" -either make a hole or order a new intake off ebay w/ a hole...
    weed101160 New Member
    you have headers? right, anyways. put your factory exhaust manifold back on
    ok, that's great. put all your factory parts back on
