Slight Problems with type A
Discussion in 'Exterior' started by Flea, Aug 17, 2004.
    Flea Guest
    lovely. I did everything the instructions said but the adhesive is starting to well...unstick in certain spots. Mostly around the corners of my back bumper and a random spot on my passanger side sideskirt. Not sure what would make it stick if the adhesive on the skirt failed. any ideas?
    SquirrelMaster New Member
    did you make sure there was no dirt on your car before you put the adhesive on? that might cause it
    Flea Guest
    positive, first thing I did was clean it all. so now I either gotta find a way to make it stick, or take it off, put more adhesive on and put it back on. Which will be a pain :?
    dvsj Guest
    Did you put on the spacers?
    Flea Guest
    the part thats coming off is no where near the spacers, and I didn't need them when I put them on. The directions just suggested them if it would make it fit better. It fit fine so I didn't use them
    dvsj Guest
    I see...cause I had the same problem, but after I installed the spacers, it pulled the lip foward to help close the gaps, which attached the lip to the bumper more than before. If the adhesive dried up, then you could buy some double sided tape and retape the area.
    Flea Guest
    The sideskirt one on side in 1 particular area is spacing a bit, along with the corners of the back bumper. The spacers should close that gap and I got some double sided tape to fix the skirt. Just hope it's not that noticable :roll:
    dvsj Guest
    So did you add the spacers that came with the kit? What was the outcome?
