Engine Short Shifter
Discussion in 'Powertrain' started by t0rres16, Jan 19, 2008.
    t0rres16 Member
    Yardley, PA
    Short Shifter
    If the short shifter from a celica or mr2 rlly fits our 8th gens wut year celica or mr2 short shifter do u guys think will fit?
    rolla996 Guest
    The most recent mr2 generation should fit for sure. However, i am not sure about the Celica however. My guess is the previous celica generation, but its just a good guess since i know the 9th gen corolla and last gen celica used many similar parts.
    VErolla Member
    Short Shifter
    I have a 98 corolla and i purchased a short shifter off ebay for like 28.00 dollars. I bought a TOYOTA CELICA 00 02 03 04 05 GT GTS short shifter. It fit perfectly. hope this helps
    t0rres16 Member
    Yardley, PA
    thx ^^ now am 100% sure i can get one
    VErolla Member
    short shifter
    Your welcome. The only issue i noticed is the small pivot ball on the celica shifter seemed a little smaller than the OEM shifter one. So the result is the celica shifter feels a little loose when you wiggle it back and forth when it is in gear. I plan to put a small piece of tubing around the ball to have a better fit, other than that i have had no issues with the celica shifter. It works well plus i think that Aluminum bushing came with it or at least my shifter came with them. So you can replace the rubber bushings with the aluminum ones and that makes a big difference also. The shift is faster and less wiggle. Difenite improvement over stock.
    t0rres16 Member
    Yardley, PA
    is it a lot shorter?
    VErolla Member
    short shifter
    Yep i would say about 1 or 2 inches shorter than stock plust it is straight and not bent like the stock shifter.
    Joeyicu New Member
    does trd make a short throw kit for the celica's?
    Yes, they do. For the GT or GTS?
    05 TRD SCed Guest
    Check out this company if you haven't already: http://www.twmperformance.com/short...ortshifters.htm
    I purchased a short shifter for my 05 Corolla from them and let me tell you, it's f@&%$*^! awesome. I would recommend that you purchase the shifter base and bronzeoil shifter cable bushings along with the shifter. If the shifter for the celica will fit then this one should to. It comes with all the necessary hardware for install as well as an install manual with photos. It truly is a high quality item and worth every penny. It'll shorten up the shifter length and make the shifting feel a lot more solid. So check it out.
    jcrwzr Member
    Simi Valley, CA
    I second the TWM for 5 speed 8th gen drivers.
    I purchased a short shifter for my 01 Corolla from them and let me tell you, it's f@&%$*^! awesome. If the shifter for the celica will fit then this one should too. It comes with all the necessary hardware for the install as well as an instruction manual with photos! It truly is a high quality item and worth every penny. It'll shorten up the shifter length and make the shifting feel a lot more solid. So check it out.
