Engine short ram intake
Discussion in 'Powertrain' started by Vibe, Apr 26, 2006.
    short ram intake
    what exactly does that part do?
    and what other engine upgrades can i get for an '01 corolla s
    lmfao...
    E91atmosk Guest
    a short ram intake is generally designed to allow more air into the engine through a larger diameter intake duct and a high performance filter. the problem with short rams is that they draw air from within the engine compartment which means that whatever HP gains you main see, they are generally small and only last while your car is cold. a much better investment would be a cold air intake, it costs a little more, but on the whole they are a much more reliable way to get more HP.
    las vegas
    The only company i know sales cai for 99-02 corolla is elprototype,but other than that go to ebay for the sri,its cheaper.
    go to http://monkeywrenchracing.com/ for upgrade your internals.
    good luck getting an ELP intake.
    thank you guys for the info!
    does anyone know how much hp/torque is in that 1ZZ-FE fully built race engine stage 4?
    monkey4005 New Member
    and no one, from what i understand, has actually gotten one from them since then.
    las vegas
    Im not sure how much hp/tq the fully built race engine stage 4,but most likely the stage 4 should give good hp/tq than the stock internals.
