shocks and springs
Discussion in 'Stop, Drop & Roll' started by slvr2000fdvspec, Dec 21, 2004.
    slvr2000fdvspec Guest
    if you want an even height, you're notgoing to get one from lowering springs, especially if you have a backdrop problem, just get some tokico struts and some groundcontrol coilovers which allow you to adjust your ride height
    locster703 New Member
    shocks and springs
    my 01 corolla s always sat low in the back now even worse with the dual 10inch supwoofers in the back along with the battery should I go with springs that lower the front more then the back an if so who makes them also can u just match up any set of springs with just any shocks what pairs with what also whats better to spend the most money on springs or shocks?
    CivicEater Guest
    you could run a higher spring rate, such as a TRD, and you may see less of a sag in the rear..
    Well you're not going to get a perfect match between spring and damper rates unless you buy some real coilover, like Teins. Besides what slvr2000fdvspec suggested though, I'd just say to get a lighter sub enclosure.
